Klipsch(클립쉬) SW-311
Klipsch(클립쉬)
Klipsch
재생 주파수 대역
22Hz-120KHz ± 3dB
최대음압
118dB @ 30Hz 1/8 space, 1m
앰프형식
BASH Digital Hybrid class-AB
앰프출력
FTC Rated Power: 500 watts continuous @ <2% THD / Dynamic Power*: 1200 watts
드라이버 유닛
10″ Active / Dual 10″ Passive non-resonant Woven Fiberglass drivers
인클로져 형식
Bass-reflex via dual side-firing passive radiators
입력단자
L/R Line-level RCA jacks, USB, 12V Trigger, MIC, WA port
출력단자
Line-level RCA jack
높이
33cm
넓이
33cm
깊이
35.6cm
무게
16.8kg
마감
Black satin
전압
220-240V~50/60Hz 5A (Auto-voltage switching) with 1Watt standby
Totem(토템) Thunder II Sub
4,200,000
Paradigm(패러다임) SUB15 서브우퍼
6,500,000
Paradigm(패러다임) SUB12 서브우퍼
3,170,000
Klipsch(클립쉬) PALLADIUM P-312W
7,200,000
JAMO(야모) SUB-210 서브우퍼
170,000
