The Control 15 embodies all three of the functions that define a Meridian Sooloos Digital Media System – storage, playback & control – in a single unit. Simply add Meridian DSP loudspeakers to create a complete system.
Storage
The Control 15 stores the equivalent of up to about 1000 CD albums in Lossless format, thanks to its internal 500GB hard drive. If additional Meridian Sooloos products with hard-disk storage are available on the network, the Control 15 will share these resources for storage, and render audio from them.
A Compact Disc drive is included in the Control 15, allowing music to be imported into the system direct from CD. Media can also be added via the Control PC and Control Mac applications.
Playback
The Control 15 features a brand-new audio output design which includes the very best of Meridian’s experience with digital sound. Digital signal processing provides the full range of digital audio features for which Meridian is renowned, such as upsampling for enhanced audio performance, and an ultra-low-jitter clocking system for superior stereo imaging and digital audio performance.
Control
The Control 15 embodies Meridian’s award-winning, ultra-intuitive Sooloos touch-screen interface, allowing instant access to a Meridian Sooloos music collection in many different ways. With a high-contrast, high-resolution 17-inch LCD display, the Control 15 features a sensitive resistive touch panel that responds instantly to a fingertip.
The Control 15 integrates fully into an existing Meridian Sooloos system, and is able to control other zones, seamlessly access additional storage and be operated from other control devices.
The latest Meridian Sooloos software offers advanced music discovery, integrating Rhapsody?* and Internet Radio services; streamlined system configuration; zone playback synchronisation; third-party control, including Crestron integration; and dedicated Sooloos iPad and iPhone applications enabling wireless control.
Media Core 200 – 완벽한 디지털 미디어 시스템
Meridian Media Core200은 세련되며 크기가 작고 팬을 사용하지않아 어떤 위치에서도 정숙한 환경을 가져다주는 미디어시스템 입니다. iPad 또는 iPhone어플리케이션을 지원하고, Control15와 Control10과 같이 PC 또는 Max등 네트워크 기반의 환경에서 운영하실 수 있습니다.
네트워크를 통하여 랩소디 서비스가 가능하며,인터넷 라디오,iTunes등 기존의 모든 뮤직 라이브러리의 음악 소스를 재생하실수 있습니다.
깔끔하고 사용하는 유저가 편리하게 사용할 수 있는 Sooloos 인터페이스를 통해 직관적이고 간단한 터치로 편리하게 사용하실수 있으며, 500GB의 하드 디스크가 내장되어있어 약 1000장의 무손실 CD파일을 저장하여 사용하실수 있으며, 확장이 필요할시 Twinstore를 추가하여 확장하실수 있습니다.
미디어 코어 200은 analoge output과 coax output, 그리고 메리디안 SpeakerLink 및 S / PDIF를 제공하므로 Meridian 오디오 시스템에 연결하실수 있습니다.
일단 SpeakerLink 통해 메리디안 시스템에 연결되면 Meridian의 오디오 랜더링 프로세스 즉 De-Jitterring,Upsampling,Apodizing filtering 그리고 DSP processing등을 거쳐 최고의 퀄리티의 음질을 즐기실수 있습니다.
또한 iTunes등 기존에 가지고있는 모든 뮤직라이브러리에서 음악을 땡겨올수 있습니다.
USB 포트는 멀리 떨어진곳의 Pc를 무선 네트워크를 통하여 원격으로 제어할수 있도록 Windows Media Center 호환 IR 수신기의 연결이 가능합니다.
Meridian Core200은 당신의 오디오 라이프에 새로운 장을 열어드릴것입니다.
Outline Technical Specification
Network Interface
• 1x Ethernet (RJ45)
Audio Connections
• Meridian SpeakerLink (RJ45)
• 1x S/PDIF coaxial digital output, RCA type
• Analogue stereo (RCA type), 2V P-P or variable level.
Other Connections
• 2x USB expansion connectors
for Windows Media Centre compatible IR receiver
for MSR+ operation and connection of
a compatible WiFi receiver.
Audio Processing
• Ultra-stable clock for lowest possible jitter
• Meridian’s apodising upsampling filter provides
ultimate digital performance
Indicator
• Single front-panel white LED pulses during startup
and shutdown, solid during operation
Power
• 12v DC, <=36W, provided by external in-line
universal supply
• Fanless, silent operation
• 1.2 kg (2.7 lbs)
Dimensions
• 93 x 264 x 253 (3.5 x 10.5 x 10in) inc feet (WHD)
Finish
• Bead-blasted and anodised aluminium.
