Dynaudio(다인오디오) Evidence Center
Sensitivity (2.83 V/1 m):
90 dB
Recommended Amp. Power:
Listening distance:
3 m: 20 watts (4 ohm)
5 m: 50 watts (4 ohm)
7 m: 100 watts (4 ohm)
10 m: 200 watts (4 ohm)
IEC Long Term Power Handling:
350 watts (4 ohm)
Impedance, Nominal:
4 ohms
Impedance, (20-200 Hz):
3.2 – 14.2 ohms
Impedance, (200-20 kHz):
3.6 – 6.5 ohms
Impedance, Phase Shift (20-200 Hz):
-42° – +21°
Impedance, Phase Shift (200-20 kHz):
-4° – +15°
Impedance, HF (200 kHz):
6.3 ohms
Frequency Response (+/- 3 dB):
38 – 23000 Hz
Resonance Frequency:
35 Hz
Internal Cabinet Volume:
36 litres
Bass Principle:
Reflex
Weight:
121 lbs. (55 kg.)
Dimensions (W x H x L):
48.00 x 8.26 x 18.27 inches
1220 x 210 x 464 mm
Crossover:
3 way
Crossover Frequencies:
400, 1900 Hz
Crossover Slope:
6 dB/oct
Connection:
CE-comp. WBT gold binding posts
Recommended Placing:
Stand or cabinet support, under video screen
Remarks:
Tweeters:
28 mm soft dome
Magnetic fluid
40 mm aluminum-alloy front with high heat-dissipation integrated in baffle
Pure aluminum wire voice coil
Aluminum-alloy rear chamber with high heat-dissipation
Over-dimensioned Neodymium magnet rings
Midranges:
15 cm one-piece moulded MSP-cone
38 mm pure aluminum wire voice coil
Propietary hybrid magnetic circuit
Woofers:
17 cm, one-piece moulded MSP-cone
75 mm pure aluminum wire voice coil
Neodymium dual-magnet rings
Magnetic fluid
Moniter Audio(모니터 오디오) NEW Bronze Center
230,000
B&W HTM71 S2 센터스피커
B&W HTM2 D3
6,000,000
B&W HTM1 D3 화이트 노오픈 신품
9,200,000
Moniter Audio(모니터 오디오) NEW Silver Centre
650,000
