Dynaudio(다인오디오) Evidence Temptation
음압 (2.83 V/1 m) : 90 dB
권장 앰프 파워 : 청취 거리 : 3 m: 20 watts (4 ohm), 5 m: 50 watts (4 ohm), 7 m: 100 watts (4 ohm), 10 m: 200 watts (4 ohm)
공칭 임피던스 : 4 ohms
주파수 응답 특성 (+/- 3 dB) : 29 – 25000 Hz
공진 주파수 : 28 Hz
내부 Cabinet Volume : 64 litres
저역 방식 : Reflex
무게 : 248 lbs. (113 kg)
사이즈 (W x H x L) : 8.26 (15.35 baseplate) x 76.10 x 19.29 inches, 210 (390 baseplate) x 1933 x 490 mm
Tweeters : 28 mm soft dome
Magnetic fluid 40 mm aluminum-alloy front with high heat-dissipation integrated in baffle Pure aluminum wire voice coil Aluminum-alloy rear chamber with high heat-dissipation
Over-dimensioned Neodymium magnet rings
Midranges : 15 cm one-piece moulded MSP-cone 38 mm pure aluminum wire voice coil Propietary hybrid magnetic circuit
Woofers:17 cm, one-piece moulded MSP-cone 75 mm pure aluminum wire voice coil Neodymium dual-magnet rings Magnetic fluid
마크레빈슨으로 구성한 하이파이 전용룸 설치기
Wilson Audio(윌슨오디오) WAMM
1,230,000,000
Wilson Audio(윌슨오디오) Sasha DAW
57,000,000
ELAC(엘락) CONCENTRO
85,000,000
PMC(피엠씨) MB2 XBD SE
92,000,000
KEF(케프) Q950 플로어 스탠딩 스피커
2,850,000
