Dynaudio(다인오디오) Evidence Temptation
음압 (2.83 V/1 m) : 90 dB
권장 앰프 파워 : 청취 거리 : 3 m: 20 watts (4 ohm), 5 m: 50 watts (4 ohm), 7 m: 100 watts (4 ohm), 10 m: 200 watts (4 ohm)
공칭 임피던스 : 4 ohms
주파수 응답 특성 (+/- 3 dB) : 29 – 25000 Hz
공진 주파수 : 28 Hz
내부 Cabinet Volume : 64 litres
저역 방식 : Reflex
무게 : 248 lbs. (113 kg)
사이즈 (W x H x L) : 8.26 (15.35 baseplate) x 76.10 x 19.29 inches, 210 (390 baseplate) x 1933 x 490 mm
Tweeters : 28 mm soft dome
Magnetic fluid 40 mm aluminum-alloy front with high heat-dissipation integrated in baffle Pure aluminum wire voice coil Aluminum-alloy rear chamber with high heat-dissipation
Over-dimensioned Neodymium magnet rings
Midranges : 15 cm one-piece moulded MSP-cone 38 mm pure aluminum wire voice coil Propietary hybrid magnetic circuit
Woofers:17 cm, one-piece moulded MSP-cone 75 mm pure aluminum wire voice coil Neodymium dual-magnet rings Magnetic fluid
마크레빈슨으로 구성한 하이파이 전용룸 설치기
KEF(케프) Q950 플로어 스탠딩 스피커
2,850,000
KEF(케프) R5 플로어스탠딩 스피커
3,900,000
179,000,000
Wilson Benesch(윌슨베네시) A.C.T One
25,500,000
ELAC(엘락) CONCENTRO
85,000,000
