    Monitor Audio(모니터오디오) BX Center 센터
  • 판매 가격 250,000
    Monitor Audio
    China
 For the BX Centre we”ve demolished the limitations of entry-level design by creating a speaker that reproduces voice with unfailing detail and accuracy. Its system of twin 140mm (5 1/2″) C-CAM? drivers and 25mm (1″) C-CAM? tweeter complements the driver architecture of other BX series speakers, to create a wide and detailed front sound-stage, characterised by pin-point imaging.
  • Versatile 2-way loudspeaker perfect for on-wall applications, stereo or surround.
  • Dual 5 1/2″ C-CAM? drivers and single 1″ C-CAM? tweeter are pitched perfectly for accurate dialogue.
  • Acoustically matched with all other BX loudspeakers for precise surround sound imaging and consistent timbre front to back.
  • Single bolt-through drivers.  A design feature which means the driver is not fixed to the front baffle and cannot transmit vibrations and therefore colouration to the cabinet.
  • Improved cabinet rigidity and stability.
  • HiVe?II port technology to speed the transit of air from the cabinet, resulting in more dynamic bass.
  • High-quality terminal panels blend easy access with high-end functionality.
  • Choice of four high quality vinyl wood finishes.
MonitorAudio(모니터오디오) BX Centre 센터 SPEC.
 주파수 응답
 60Hz – 30kHz
 음압  90 dB
 인피던스  8 ohms
 정격출력  120 W
 권장앰프 출력  20 – 120 W
 드라이버 유닛  2 x 140mm (5 1/2″) C-CAM? bass mid-range driver.
 1 x 25 mm (1″) gold dome C-CAM? tweeter
 크로스오버  3.2kHz
 크기 (H x W x D mm)
 166 x 460 x 165 mm
 무게(개당)  6.18 Kg
