    ONKYO(온쿄) A-9000R 인티앰프
  • 판매 가격 2,000,000
Item Value
Amplifier Section
Rated Output Power (Stereo):
2 ch × 75 W at 8 ohms, 20 Hz – 20 kHz, 0.05%, 2 ch driven (IEC)
2 ch × 140 W at 4 ohms, 20 Hz – 20 kHz, 0.05%, 2 ch driven (IEC)
Dynamic Power** IEC60268-Short-term maximum output power
450 W (1 Ω)
310 W (2 Ω)
230 W (3 Ω)
180 W (4 Ω)
100 W (8 Ω)
THD+N (Total Harmonic Distortion+Noise) 0.006% (1 kHz, half power)
Damping Factor 130 (1 kHz, 8 Ω)
Input Sensitivity and Impedance (Unbalance)
150 mV/47 kΩ (LINE)
2.25 mV/47 kΩ (PHONO MM)
0.18 mV/ 100 Ω (PHONO MC)
Rated RCA Output Level and Impedance 1 V/300 Ω (PRE OUT)
Maximum RCA Output Level and Impedance 5 V/300 Ω (PRE OUT)
Phono Overload
70 mV (MM 1 kHz 0.5%)
5.2 mV (MC 1 kHz 0.5%)
Frequency Response 10 Hz – 100 kHz/+0 dB, –1 dB 1 W/8 Ω
1 Hz – 250 kHz/+0 dB, –3 dB 1 W/8 Ω
Tone Control Characteristics ±10 dB, 80 Hz (BASS)
±10 dB, 10 kHz (TREBLE)
Signal to Noise Ratio 107 dB (LINE, IHF-A)
60 dB (PHONO MM, IHF-A)
70 dB (PHONO MC, IHF-A)
Speaker Impedance 4 Ω – 16 Ω (Speakers A or B)
8 Ω – 16 Ω (Speakers A + B)
HICC 140 A
General Section
Power Supply AC 230 V, 50 Hz
Power Consumption 300W
Standby Power Consumption 0.2W
Dimensions (W × H × D) 435 mm × 175 mm × 435 mm
Weight 18.5 kg
■ Audio Inputs
Digital Inputs -Optical: 1
-Coaxial: 2
-AES/EBU: 1
Digital Inpt Format 2ch PCM
Digital Input Sampling Rate
32kHz/44.1kHz/48kHz/88.2kHz/96kHz compatible (OPT)
32kHz/44.1kHz/48kHz/88.2kHz/96kHz/176.4kHz/192kHz compatible (COAX,AES/EBU)
44.1kHz/48kHz/96kHz/192kHz compatible (USB)
Analog Stereo Inputs LINE 1, LINE 2, LINE3, PHONO (MM/MC), MAIN IN
■ Audio Outputs
Analog Stereo Outputs LINE OUT, PRE OUT
Speaker Outputs 4
Phones 1(6.3 ø)
■ Others
RI 2
PC Interface USB
