| Specfications |
| Frequency Response |
| Input Impedance |
| Maximum output level |
| Signal-to-Noise Ratio |
| Gain |
| Power Requirements |
| Height |
| Width |
| Depth |
| Weight |
45,000,000원
8,450,000원 5,500,000원
4,040,000원 1,600,000원
