| Specfications |
| Frequency Response |
| Input Impedance |
| Maximum output level |
| Signal-to-Noise Ratio |
| Gain |
| Power Requirements |
| Height |
| Width |
| Depth |
| Weight |
8,300,000원 850,000원
3,300,000원
280,000원
