Specfications |
Frequency Response |
Input Impedance |
Maximum output level |
Signal-to-Noise Ratio |
Gain |
Power Requirements |
Height |
Width |
Depth |
Weight |
280,000원
18,000,000원 8,500,000원
3,300,000원
3,500,000원
