Specfications |
Frequency Response |
Input Impedance |
Maximum output level |
Signal-to-Noise Ratio |
Gain |
Power Requirements |
Height |
Width |
Depth |
Weight |
3,600,000원
4,040,000원 1,600,000원
3,300,000원
82,000,000원
