Dynaudio(다인오디오) Confidence C2 Platinum
28 Hz – 25 kHz (± 3 dB)
40 kg
238/420 x 1532 x 445 mm
9.4/16.5 x 60.3 x 17.5″
Klipsch(클립쉬) RB-61 II
680,000
KEF(케프) R5 플로어스탠딩 스피커
3,900,000
Dynaudio(다인오디오) Excite X12
1,200,000
Klipsch(클립쉬) B-20
315,000
