Dynaudio(다인오디오) Confidence C2 Platinum
28 Hz – 25 kHz (± 3 dB)
40 kg
238/420 x 1532 x 445 mm
9.4/16.5 x 60.3 x 17.5″
Klipsch(클립쉬) B-20
315,000
Dynaudio(다인오디오) DM 2/7
1,080,000
Dynaudio(다인오디오) DM 2/6
1,040,000
Wharfedale(와피데일) Diamond 122
480,000
