Dynaudio(다인오디오) Confidence C2 Platinum
28 Hz – 25 kHz (± 3 dB)
40 kg
238/420 x 1532 x 445 mm
9.4/16.5 x 60.3 x 17.5″
KEF(케프) Q350 북셀프 스피커
1,250,000
Dynaudio(다인오디오) Excite X12
1,200,000
Dynaudio(다인오디오) DM 2/7
1,080,000
B&W 707 S2 (단종)
B&W 706 S2 (단종)
