JAMO(야모) C9 CEN 센터스피커
Klipsch(클립쉬) R-25C 센터스피커
350,000
Paradigm(패러다임) Prestige 45C
1,980,000
Moniter Audio(모니터 오디오) NEW Bronze Center
230,000
Paradigm(패러다임) Prestige 55C
2,510,000
