JAMO(야모) C9 CEN 센터스피커
Aerial Acoustics(에어리얼 어쿠스틱) CC3B
B&W HTM72 S2 센터스피커
980,000
Dali(달리) EPICON Vocal
5,500,000
KEF(케프) R2C 센터스피커
1,560,000
