Moniter Audio(모니터 오디오) NEW Gold C350
1,500,000
Paradigm(패러다임) Prestige 45C
1,980,000
6,500,000
KEF(케프) R2C 센터스피커
1,560,000
B&W HTM71 S2 센터스피커
