6,500,000
KEF(케프) R2C 센터스피커
1,560,000
Klipsch(클립쉬) R-25C 센터스피커
350,000
Paradigm(패러다임) Prestige 55C
2,510,000
JAMO(야모) C10 CEN 센터스피커
1,000,000
