    Benz Micro(벤츠마이크로) Gold MC카트리지
  • 판매 가격 450,000
    Benz Micro(벤츠마이크로)
    Benz Micro
    Switzerland
The entry models to the Benz Micro line provide the musicality we are famous for combined with affordability and a wide range of turntable/tonearm compatibility.
The Gold is a low output moving coil at .4mV at 3.54cm/sec, perfectly suited for moving coil phono stages with 60dB or higher gain. The Silver high output (2.5mV at 3.54cm/sec) is ideal for m type phono stages, low-gain tube phono stages and AV systems. These models let you enjoy the Benz Micro sound and provide an upgrade path to the Swiss hand-made cartridges.
Specifications:
Output Voltage (3.54 Cm/sec) .5 (Gold)
Stylus Shape .3 x .7 mil
Internal Ohms 20 (Gold)
Loading Range >200 (Gold)
Weight 5.7 grams
Compliance 15
Tracking 1.7 – 2 grams
Warranty 2 years
