영국 AMR Audio사의 DAC 겸 프리앰프인 DP-777 중고 상품 입니다.
다양한 디지털 입력을 지원하며 아날로그 입력도 지원하는 DAC 겸 프리앰프로 사용가능한 디지털 스테리오 프로세서 입니다.
중고 상품으로 내외관 모두 좋으며, 기능성능 모두 좋습니다.
외관 : 중고상품으로 내외관 모두 좋습니다.
부속 : 본체, 메뉴얼 박스등
Operation modes High-Definition 32-Bit DAC
Organic 44.1/48/88.2/96/176.4/192KHz
Apodising 808 44.1/48kHz
MP Listen 44.1/48/88.2/96/176.4/192KHz
Traditional 44.1/48/88.2/96/176.4/192KHz
Classic 16-Bit Multibit DAC
Bit-Perfect I; no digital or analogue filter
Bit-Perfect II; no digital filter, sinc(x) analogue filter
Digital Audio Inputs 2 x XLR/BNC with HD Valve Digital Input technology
2 x RCA/Toslink SPDIF Interface
1 x 24/192 Asynchronous USB Input
Analogue Inputs 2 x RCA per channel
Analogue Outputs 1 x RCA/XLR per channel
Thermionic Electron Valves amplification stage 2 x GE 5670 (NOS) / 1 x 6H11P fitted
Output voltage (Digital Full Scale) >2V
Frequency Response 20Hz to 20 kHz +0.0, -0.5dB
Signal-to-noise ratio “A” Weighted >100 dB
Total Harmonic Dist. + Noise (THD+N) <0.3%
Dynamic range >90 dB
Channel separation >90 dB
Power Transformer 32 VA Custom EI Transformer (Digital Section)
40 VA Custom EI Transformer (Analogue Section)
Power consumption Standby < 1 W
Power on < 60W
Rated voltage 115/230V~ AC 50Hz – 60Hz
Colour Silver or Black
Dimensions 17.7 in W by 4.7 in H by 14.6 in D
45 cm W by 12 cm H by 37 cm D
57 cm W by 49 cm H by 25 cm D (shipped)
Weight DP-777 25.4 lbs / 11.5 kg
Shipped 34.2 lbs / 15.5 kg
