Output power:2*100W into 8 ohms load. 2*180W into 4 ohms load.
Minimum load: 2 ohms
Analog Inputs:
1*balanced (XLR)
3*unbalanced (RCA)
Digital Inputs:
1*coaxial S/PDIF.
2*optical S/PDIF.
1* USB.
1* aptX HD Bluetooth (Optional Extra)
Line output:
1*unbalanced (RCA)
1*Pre-out /unbalanced variable (RCA)
Line input impedance: 50 K ohms
Phono input impedance: 47 K ohms (MM)
Phono input Capacitance: 200 pF
Line Inputs sensitivity: 250 mV
Phono sensitivity: 2.6 mV
Frequency response: 10 Hz – 150 kHz -3dB
T.H.D: Better than 0.06 %
Signal / noise IHF-A: Better than 90dB
Phase: Inverting
Headphone amp.Gain: 22 dB @ 100 ohms load impedance
Headphone amp. Out imp:40 ohms
Headphone amp. T.H.D: Better than 0.05 %.
Freq. resp. 10 Hz – 150 kHz / -3dB
Vacuum tubes:1 pc. 6922
Power consumption: Max.700 W
Dimensions: 435mm (w) x 135mm (H) x 370mm (D)
Shipping weight: 14 Kg.
