    Rega(레가) EP(도넛판) 45 RPM ADAPTOR
  • 판매 가격 55,000
    Rega(레가)
    Rega
    United Kingdom
45 RPM  7인치 도넛판(EP) 용 어텝터 입니다.
The record adaptor has been designed to be used with your 45rpm records that no longer have the centres, enabling you to play your old favourites.
The adaptor is simply fitted over the spindle of your turntable and the record will fit the outside of the adaptor. Then simply sit back, switch on and enjoy the music.
