    Rega(레가) 톤암 높이 조정용 2mm 스페이서-실버
  • 판매 가격 65,000 55,000
    세일
    Rega(레가)
    Rega
    United Kingdom
레가 턴테이블의 톤암의 V.T.A (톤암높이) 조절용 스페이서 어텝터 입니다.
레가 이외 타사 카트리지 사용시 높이 조절이 필요할경우 사용하는 스페이서 아탑터 입니다.
2mm 높이로 오토폰 Cadenza 기준 2개 (4mm) 가 필요합니다.
레가 플레너 1에서 10 까지 사용가능합니다.
2MM THREE POINT ARM HEIGHT ADJUSTMENT SPACER – STAINLESS
Some other manufacturers cartridges may have a deeper body than Rega cartridges, these will sometimes require the use of the three-point spacer to allow clearance of the rear of the cartridge from the vinyl.
When Rega arms are fitted to turntables from other manufacturers it may be necessary to add our Rega arm spacers to achieve the correct arm height.
Note On Rega turntables, spacers should not be necessary unless you are you using an exceptionally deep-bodied cartridge from another manufacturer.
Arm height or V.T.A adjustment can be a controversial subject. Rega believes that the integrity of the arm fixing onto the arm mounting board is much more important than the questionable facility of arm adjustment. The arm should be reasonably parallel to the record surface or slightly lower at the mounting. The only time a spacer is necessary to raise the arm height is if the rear of a cartridge is hitting the record whilst playing.
