    Van den hul(반덴헐) Sky Line HYBRID 스피커 케이블 1m(벌크)
  • 판매 가격 9,500
    품절 신상품
    Van Den Hul(반덴헐)
    Van Den Hul
*1m 단위의 가격입니다. 5m가 필요하신 고객님께서는 수량을 5개로 구입해 주시면 됩니다.
The SKYLINE HYBRID is an elegant small twin conductor loudspeaker cable with outstanding qualities.
The SKYLINE HYBRID is a low priced member of our AWG 14 twin-lead loudspeaker cable range which consists of The GOLDWATER, The CLEARWATER, The SNOWLINE and The SKYLINE HYBRID.
The SKYLINE HYBRID is the only Hybrid cable in this range:
Each lead combines 19 high purity Oxygen Free Copper strands with a coating containing our Linear Structured Carbon ®;
This combination of metal and carbon (hybrid technology) has excellent properties when it comes to resolution and neutrality, and therefore is standard applied in all of our heavier loudspeaker cables.
The SKYLINE HYBRID has been designed to be less flexible than its above mentioned colleagues, reflecting its aim to be used in more permanent high quality loudspeaker wiring applications.
The SKYLINE HYBRID is 8.5 mm. wide and 3.4 mm. thick.
Each of its two 2.04 mm² conductors exhibit a resistance of 0.84 Ohm/100 m.
The cable’s jacket is made of sky-blue coloured HULLIFLEX ® 3, a robust halogen free material excellently capable of shielding the copper conductors from the chemically threatening outside world.
The cable’s sky-blue color quite accurately represents its sonic character: as clear as a cloudless blue sky.
The insulation of both conductors has a different shape: one is round and the other has two edges with type printing on the flat surface: the most simple polarity finder you can think off. Type printing at 25 cm. (10″) distance facilitates cutting of lengths.
The SKYLINE HYBRID is available:
In any length with, as desired, either our 3.0 mm. Ø cable entrance diameter Bus type Universal Speaker Connectors or our DIY Screw-On Speaker Connectors mounted.
On 100 m. reels:
Shipping: 1 x 100 m. reel in a 275 x 275 x 220 mm. box with a total shipping weight of 6.2 kg.
2 x 100 m. reel in a 275 x 275 x 220 mm. box with a total shipping weight of 13.2 kg.
각각의 리드선은 반덴헐의 Linear Structured Carbon ®을 포함하여 코팅처리 되어 있는 19개의 고순도 무산소 구리(OFC) 스트랜드로 결합되어 있습니다
이들 메탈과 카본의 결합(하이브리드 기술)은 해상도와 중립성면에서 탁월한 특성을 제공하며, 결과적으로 반덴헐의 보다 큼직한 모든 스피커 케이블에 표준으로 적용됩니다.
SKYLINE HYBRID는 보다 영구적인 고급 스피커 와이어링 어플리케이션에 사용될 수 있도록 위에서 언급되었던 모델들에 비해 다소 유연성이 덜하도록 디자인 되었습니다.
SKYLINE HYBRID는 8.5mm입니다. 넓고 3.4mm. 두꺼운.
2 개의 2.04 mm² 도체 각각은 0.84 Ohm / 100 m의 저항을 나타냅니다.
본 케이블의 외피는 외부의 화학적 침범으로부터 이 구리 전도체를 훌륭히 보호할 수 있는 스카이 블루 색상의 단단한 HULLIFLEX ® 3 소재로 구성되어 있으며, 본 케이블은 청명한 파란 하늘처럼 맑고 깨끗한 사운드 특성을 전달합니다.
양쪽 컨덕터의 절연재는 각기 다른 모양으로 구성되어 있습니다 – 한 쪽은 라운드형(원형)이며, 다른 한 쪽은 평평한 표면 상에 타이프 프린팅을 해 놓은 2 가닥의 에지(끝단)로 이루어져 있습니다 – 이들 특성은 극성을 보다 손쉽게 구별할 수 있도록 해줍니다. 또한 25cm 마다 타이프 프린팅이 되어 있어 길이 절단에 용이합니다.
