    Magnum Dynalab(매그넘) ST-2 FM안테나
  • 판매 가격 250,000
    Magnum(매그넘)
    Magnum
매그넘 다이나랩의 FM 안테나 입니다.
뛰어난 수신을 원하신다면 적극추천드립니다.
[제품설명]
ST-2 FM Antenna. A Vertical, Omnidirectional FM Antenna
Receives distant FM stations from all directions!
A more powerful FM Antenna than any single element dipole antenna, the ST-2 vertical is probably one of the best things ever to happen to FM listeners in urban and fringe reception areas alike.
Concentrating its reception “focus” only on the horizontal plane, the ST-2 is capable of getting more signal to your FM tuner with less “flutter” and “fading.”
The ST-2 is also less susceptible to “multipath interference,” due to its unique vertical polarization.
Right from its PH17-7 stainless steel whip through the gold-plated coil coupling to the stainless-steel encased, precision-wound loading coil, the ST-2 is built tough. Yet it passes the most fragile of FM signals to your FM tuner”s circuitry with the kind of strength sometimes found only with much larger, multi-element antennas.
Being a 1/2 wave design and not requiring a “ground plane” or counterpoise,” it is equally at home mounted on a mast, a balcony, hanging in the window or from a tree. The ST-2 offers greatly enhanced FM tuning performance,and signal strength.
The ST-2 comes to you ready to install. It is 54 inches in length, and furnished with a stainless steel “L” mounting bracket for ease of installation both in and outdoors.
황인식
2020년 12월 8일
아파트(분당) 실내에서도 FM 수신이 가능한지요? 일발 줄로된 안테나 설치해 보니 잡음이 많거든요. 본 안테나로 아파트에서 FM 수신이 된다면 구매 하고 싶습니다
2020년 12월 8일
분당 지역이 난청지역이 좀 있어서 실내 안테나로는 완벽한 수신은 좀 힘드실것 같고 메그넘 전용 외장 안테나를 베란다 등 외부에 설치하셔야 하실것 같습니다.
