    Aura neo : CD Player + DAC
  • 판매 가격 1,200,000
    Aprilmusic(에이프릴뮤직)
    Aprilmusic
주요기능
■ 입력단의 Ground Isolation
– ground loop 잡음이 생기기 쉬운 외부 기기 입력(PC USB, COAX)과 ground 분리
■ 전원회로
-Custom made Power Supply
– Hardware Function 블럭 별로 별도의 정전압 전원회로 사용
■ DA converter
– Sampling rate : COAX, OPTIC – up to 96KHz, PC USB – up to 48KHz
– DIR : AX4117, ASRC : AK4125, DAC : CS4398, USB DAC : PCM2704
– 140 dB Dynamic Range, THD + N : 130 dB
– 4th order digital filter
– upsample up to 192KHz
■ CD 부
– Toshiba CD Servo chipset,
– Top loading Sanyo pick-up
– CD-DA, CD-R, CD-RW
– Micro switch for CD sliding door limit
■ 아날로그 출력
– J-FET 입력 구조로 입력 임피던스가 매우 높아 안정된 버퍼 역할
– 독립된 언밸런스/ 밸런스 출력회로
– 출력 임피던스 : 100 Ohms
■ Quality component
– Nertrik Balanced 코넥터, Gold plated RCA, 1% 오차 저항
주요리뷰
Image Gallery
Top-loading mechanism for best CD playback
3 digital inputs pc USB Link, COAX, TOS
2 main analog outputse XLR, RCA
2 digital outputs COAX, TOS
Remote-selectable ASRC upsampling
BYPASS, 96kHz, 192kHz
Display Device 14 segment alphanumeric LED
Full Function Remote Control
Dust barrier protects CD mechanism
Dimension W286 x D278 x H78 mm
Weight(Net) 4.1 kg
