Highest Standard of Technological Excellence
Studio speakers offer the highest standard of technological excellence resulting
in a breathtaking quality of music reproduction that captures the essence of the
original sound.
Equally important is the speakers’ performance in home theater. Movie soundtracks
are a complex mix of dialog, music and action effects. This requires a level of articulation and spatial representation that few movie theaters are capable of reproducing. Studio speakers exceed typical high-end home theater sound by expanding the sheer size, scale and dynamics of the acoustic soundstage. While listening to a Studio system The Perfect Vision magazine put it best: “It’s just like being at the movies — except the sound is
a lot better.”*
*Nicholas Bedworth, The Perfect Vision on the Studio 100
G-PAL™ Gold-Anodized Pure-Aluminum Domes. Exceptionally rigid low-mass domes with treated textile suspensions ensure remarkably uniform and instantaneous power response. The elevated position of the dome provides better ‘air’ and frequency response that is smooth, pure and clear.
S-PAL™ Satin-Anodized Pure-Aluminum Midrange and Bass / Midrange Cones. Very high stiffness-to-mass ratio and outstanding internal damping. The result? Remarkable midrange clarity, superb extended bass response and freedom from unwanted resonances and distortions.
IMS/SHOCK-MOUNT™ Isolation Mounting System. This unique butyl-rubber driver fastening system found on all Studio Series drivers is a progressive system of critically placed isolation inserts and gaskets that decouple drivers from the speaker enclosure itself. This leading-edge ‘baffle-less’ technology reduces driver / enclosure interactions to inaudible levels.
High-Velocity Low-Noise Aluminum Ports. Bass efficiency and minimum turbulence distortion for cleaner and more articulate bass response.
Beautifully Sculpted Cabinets with Real Wood Veneer Finishes. Add a whole new dimension to the classic appeal of this series. Seven coats of the highest quality lacquer, hand-sanded between coats. Available in four luxurious real wood veneer finishes.
SPECIFICATIONS |
Design |
5-driver, 3-way floorstanding |
Crossovers |
3rd-order electro-acoustic at 2.0 kHz; 3rd-order electro-acoustic at 300 Hz (bass drivers) |
High-Frequency Driver |
25-mm (1 in) G-PAL™ dome, ferro-fluid damped / cooled, die-cast heatsink chassis, IMS/SHOCK-MOUNT™ |
Midrange Driver |
178-mm (7 in) S-PAL™ cone, 38-mm (1-1/2 in) voice-coil, AVS™ die-cast heatsink chassis, IMS/SHOCK-MOUNT™ |
Bass Drivers |
Three 178-mm (7 in) mineral-filled polypropylene cones, 38-mm (1-1/2 in) voice-coils, AVS™ die-cast heatsink chassis, IMS/SHOCK-MOUNT™ |
Low-Frequency Extension* |
25 Hz (DIN) |
Frequency Response: On-Axis 30° Off-Axis |
±2 dB from 44 Hz – 22 kHz ±2 dB from 44 Hz – 20 kHz |
Sensitivity – Room / Anechoic |
93 dB / 90 dB |
Suitable Amplifier Power Range |
15 – 350 watts |
Maximum Input Power† |
230 watts |
Impedance |
Compatible with 8 ohms |
Height, Width, Depth |
112.0 cm x 24.1 cm x 43.1 cm 44-2/16 in x 9-1/2 in x 17 in (heights include spikes or outrigger feet; widths exclude feet) |
Weight (unpacked) |
35.4 kg / 78 lb each |
Finishes |
Cherry, Rosenut, Black |
REVIEWS
Studio 100 Review – AUDIO
Studio 100 Review – Audio Ideas Guide
Studio 100 Review – Audio Video
Studio 100 Review – Australian Hi Fi
Studio 100 Review – Sensible Sound
Studio 100 Review – SoundStage!
Studio 100 Review – Stereo411.com
Studio 100 Review – STEREOPHILE
Studio 100 Review – The Absolute Sound
Studio 100 Review – The Audiophile Voice
Studio 100, CC, ADP & Servo-15 Review – The Perfect Vision
Studio 100, CC-470 & Studio 20 Review – The Perfect Vision
Studio 100, CC-570 & ADP-470 Review – audiorevolution.com
Studio 100, CC-570, ADP-470 & Seismic™ 12 Review – The Perfect Vision
Studio 100, CC-690, ADP-590 & Servo-15 Review – Audio Video Revolution
