    CHORD(코드) CPA 5000 + SPM 1400 MK. II 프리 모노파워
  • 판매 가격 50,500,000 48,000,000
    품절 세일
    CHORD(코드)
    CHORD
    England
The CPA 5000 is one of two ultra-high-performance models in the flagship Reference range, representing our finest preamp engineering. The CPA 5000 offers a substantially larger chassis than our Standard Series preamps and contains the latest proprietary ultra-high-frequency power supply. When combined with our ultra-low-noise circuitry, the technologies give the CPA 5000 an incredible noise floor performance of below -130dB.
The CPA 5000 is highly flexible, too. It offers four pairs of fully balanced inputs, four pairs unbalanced inputs, plus two completely independent tape/recording loops. Each input has six levels of gain that can be individually selected to prevent large changes in volume when switching between inputs and all settings are stored via a microprocessor, even if power is removed. The CPA 5000 also includes two low-distortion, low-noise front panel headphone outputs to exploit the full potential of today’s high-quality headphones and give added flexibility for late-night or personal listening.
Also included, is fully balanced A/V bypass circuitry for direct connection to A/V processors, 12V remote triggering outputs at the rear of the unit to activate power amplifiers or A/V processors on power-up, plus Chord’s legendary aircraft-grade solid alumi
Frequency Range:
2.5Hz – 200kHz +/- 3dB
Total Harmonic Distortion:
0.002% 20Hz – 20kHz
Intermodulation Distortion:
-120dB on all inputs
Signal to Noise Ratio:
Channel Separation:
20Hz @ 100dB, 1kHz @ 95dB, 10kHz @ 90dB, 20kHz @ 85dB
Channel Balance:
0.01dB
Input Max Voltage:
17v RMS Balanced – 8.5v RMS Unbalanced
Output Max Voltage:
Output Offset:
0mV (Both Channels)
Potentiometer Performance:
0dB 0.5dB, -20dB 0.2dB, -60dB 0.24dB (13seconds Full Travel)
Nominal Gain:
All inputs subject to six levels of switchable gain – x0.5, x1, x1.5, x2, x2.5, and x3
Input Impedance:
100 kΩ Balanced – 50 kΩ Unbalanced
Output Impedance:
100Ω (Short Circuit Protected)
Operating Voltage:
85v – 270v AC (50Hz – 60Hz) Auto Switching
Power Consumption:
30w
Dimensions Without Integra Legs:
420mm (w) x 355mm (d) x 133mm (h)
Dimensions With Included Integra Legs:
480mm (w) x 355mm (d) x 173mm (h)
Weight:
18kG
With Chord Electronics Limited’s considerable experience in the design and manufacture of the world’s best consumer and professional amplifiers, we are proud to announce our latest design of power amplifier utilising our high frequency power supply techniques and our own proprietary lateral structure dual-die MOSFETs. This amplifier provides all the benefits of mono amplification whilst retaining all of the much loved qualities of Chord Electronics amplifiers. Improvements in capacitor technology have boosted secondary reservoir levels to 94,000 µF storing over 381 Joules of energy. A “Superamp” in all but dimensions, this amplifier is for those whose goal is direct comparison between live and recorded music, a sentiment echoed by reviewer and customers alike.
Hi-Fi News magazine recently praised the latest-generation SPM 1400MkII mono power amp in its September 2013 edition. The issue features an in-depth review of our new mono power amp and sums up by saying: “Beautiful to behold by both eye and ear, Chord’s MkII SPM 1400 monoblocks offer spectacular insight into music. Majoring on clarity, timing and delivering natural realism like few other power amps at any price, they tick every box in the audiophile hi-fi check list. Neutral, detailed and with breathtaking resolution.” Hi-Fi News gave the ‘1400MkII their ‘Highly Commended’ award. You can download the full review below.
A high current mains filter ensures that the amplifier is shielded from disturbed mains as well as ensuring that the mains is untouched by emissions from the amplifier. The output from the power supply uses a truly innovative “Dynamic Coupling” technique whereby the positive and negative rails are mutually coupled by a strong magnetic flux. The result being that if a high demand is put on one rail, the energy required is actually drawn equally from both rails. This keeps the amplifier balanced dynamically and the reference point perfectly clean.
Output Power:
480w RMS per channel @ 0.05% distortion into 8Ω
800w RMS per channel into 4Ω
Frequency Response:
-1dB @ 0.2Hz to 46kHz and -3dB 0.1Hz to 77kHz
Better than -103dB
Channel Separation:
Better than 90dB
Input Impedance:
100kΩ Unbalanced/Balanced
Output Impedance:
0.04Ω
Gain:
30dB
420mm (w) x 355mm (d) x 150mm (h)
480mm (w) x 355mm (d) x 190mm (h)
Weight:
24kg
