    JBL(제이비엘) L100 Classic
  • 판매 가격 6,700,000원
    JBL(제이비엘)
SPEC
LOW-FREQUENCY TRANSDUCER 12-inch (300mm) Pure Pulp cone (JW300PW-8)
HIGH-FREQUENCY TRANSDUCER 5-1/4 inch (130mm) Polymer-coated, Pure Pulp cone (105H-1)
ULTRAHIGH-FREQUENCY TRANSDUCER 1-inch (25 mm) Titanium dome with soft surround (JT025TI1-4)
RECOMMENDED AMPLIFIER POWER 25-200 Watts RMS
FREQUENCY RESPONSE 40Hz-40kHz (-6dB)
NOMINAL IMPEDANCE 4 ohms
SENSITIVITY 90dB
CROSSOVER FREQUENCIES 450Hz, 3.5kHz
CONTROLS Attenuators for MF and HF drivers
CONNECTOR TYPE Five-way gold-plated Binding Posts
FINISH Genuine walnut veneer enclosure with Quadrex foam grille in a
choice of Black, Burnt Orange or Dark Blue
DIMENSIONS (H X W X D) (636.6mm x 389.7mm x 371.5mm)
WEIGHT 58.5 lb (26.7 kg) each
